Calculation Surface Origin / Center
DAB LAD
Post by DAB LAD » Sun Jan 21, 2018 1:53 pm
I found this small bug.
When you create a calculation surface in a room.
The center of that calculation surface would be the room where it is allocated.
Now problem arises in documentation when the center of the calculation surface is not within the room itself.
For example if you are dealing with L shaped or irregularly shaped rooms and the calculation surface center inadvertently become located in another room.
And then in documentation it would be included in that room.
Anyway. Keep up the good work in EVO. It defintely has come a long way.
Also the autosave/backup feature needs some work. If you forgot to save for half a day. You lose half a day of work if it crashes. And the backup file is from when you last save.
Re: Calculation Surface Origin / Center
Post by T.Magenheimer » Wed Jan 24, 2018 6:07 pm
Dear DAB LAD,
We will discuss your both mentioned points with our product owner and we will add it to our improvement list of evo.
