Triangle window
Mione
Triangle window
Post by Mione » Wed May 08, 2019 3:08 pm
Is it possible to build a triangle window, because I want to calculate daylight and I'am using the tool cut but it's not working.
Re: Triangle window
Post by Csuleiman » Wed May 08, 2019 7:05 pm
Hello Mione,
Unfortunately, it is not possible to create a triangular window for the daylight calculation.
If you would like to calculate daylight, then you have to use daylight relevant DIALux windows/skylights. Only with these windows, it is possible to calculate the daylight in your project file. All other building openings made by cut-outs are not taken into account.
The calculation of the illumination takes place only in the interior and only by daylight relevant windows, which conduct the daylight inside the building. Other building openings are not considered in the calculation of daylight. Windows that are inside the building are not relevant for daylight.
We will add your wish for such a triangle window as a new point to our improvement list of evo. This list is the basis for the development of the upcoming evo versions.
Mione
Re: Triangle window
Post by Mione » Thu May 09, 2019 1:20 pm
Thank you
