Vertical illuminance uniformity
gaubhat@gmail.com
Post by gaubhat@gmail.com » Fri May 03, 2019 4:28 am
How caan I increase uniformity of Vertical illuminance ?
In case of horizontal illuminance,when uniformity is less,I simply add a luminaire at the place where illuminance numbers are less.
But that is not possible for uniformity of Vertical illuminance.
Please help.
Thanks,
Gaurav
Re: Vertical illuminance uniformity
Post by Csuleiman » Fri May 03, 2019 9:16 am
Hi Gaurav,
You must increase the minimum value of the illuminance calculated on the calculation surface in order to increase the uniformity (min/average).
gaubhat@gmail.com
Post by gaubhat@gmail.com » Fri May 03, 2019 10:13 am
Yes I can do that.
But,how can I do it for vertical illuminance?
As the luminaire is same and has no relation with horizontal and vertical illuminance.
I have sent my file on ur email ID..Can you check it?
Thanks,
Post by Csuleiman » Thu May 09, 2019 9:55 am
Hi Gaurav,
So far we have not received any email from you.
gaubhat@gmail.com
Post by gaubhat@gmail.com » Fri May 10, 2019 4:21 am
Hi there,
I have a doubt again!
In the project manager window,in the calculation tab, what should be the angle in degrees for calculating vertical illuminance?and what should be the height?
Thanks,
Gaurav
Post by Csuleiman » Fri May 10, 2019 5:50 am
Hi Gaurav,
We cannot answer this question. The parameters depend on how your lighting design is to be made.
