Are Calculation Grids editable? (.dwg exporting)
Beca_539
Post by Beca_539 » Fri Apr 19, 2013 2:28 am
Just a quick question. Does anyone know if you can change the decimal points on the calculation grid output? and also change the text style and size? I'm currently exporting .dwgs of models and i want to change the decimal point from the standard 2 points to 1 decimal point e.g. 2.00 becomes 2.0. Also is it possible to change the text from the standard output to say Arial Narrow, and change the text height? I have found out how to change the text height (through the output section. Refer to screen shoot) but this does not change in the .dwg export. It only works for pdf exporting or printing. And i have also tried in the value chart section under the export settings (refer to scrren shot), but this only changes the text hight of value charts, not calculation grids.
If it is not possible can you please put it on the wishlist.
Cheers
[attachment=1]dialux 1.jpg[/attachment]
Sceen shot 2
dialux 2.jpg (52.98 KiB) Viewed 6951 times
Screen shot 1
dialux 1.jpg (238.05 KiB) Viewed 6951 times
sdette
Re: Are Calculation Grids editable? (.dwg exporting)
Post by sdette » Wed May 08, 2013 12:08 pm
Hi beca,
Thank you very much for your attention and support.
Unfortunately it is not possible to change the text style and size in our DIALux software.
