Emergency Lighting Calculation Surfaces
khird
Post by khird » Thu Sep 30, 2021 11:56 am
Can you explain how to alter the anti panic surface shape/points to better accommodate unusual room geometry, e.g. move an edge closer or further away from a wall.
I'd also like to understand how to add a cut out around columns and internal partition walls. Currently the anti panic surface does not leave any distance around room objects, creating some weird results. In Relux you can specify how far away from a column or other object the emergency surface stops.
Re: Emergency Lighting Calculation Surfaces
Post by Csuleiman » Wed Oct 06, 2021 8:06 am
Hello khird,
The points you mentioned are also still on our radar. We hope to be able to address these optimisations in the emergency lighting feature in early 2022.
