Different floor colors/materials in the same room
rosivaldo
Post by rosivaldo » Sat Feb 29, 2020 1:07 pm
How can I create two or more separate regions/surfaces on the floor of a single room in order to assign a different color/material to each separate region/surface?
Thanks in advance.
Rosivaldo.
Re: Different floor colors/materials in the same room
Post by Csuleiman » Mon Mar 02, 2020 7:22 am
Hello rosivaldo,
You can insert a thin cube, which has the appropriate room geometry, into the separated room. Then you will be able to use a another texture/ material just for this area. Or the better way would be to create this room by using new indoor contour. Then you will have a real room in a room. If you click on the SHIFT key whilst drag&drop the colour to the floor, you will only get for one room and one floor the material as required. Maybe you can check it out.
