Sequence selected calc. surfaces in Documentation report
AntoonB
Post by AntoonB » Thu Oct 24, 2019 9:33 am
I have a question regarding the sequence of selected calculation surfaces I am using in a calculation.
I have numbered the calculation surfaces (01, 02, 03 .. etc) and I would like to report these
numbers in the same sequence out of the report in "Documentation".
But as you can see EVO is mixing this together when I select the surfaces in
Documentation - selected output - Technical Planner - edit.
I have attached a printscreen with red arrows to some numbers where the right sequence
is mixed together by EVO.
Dialux EVO - documentation - selected output.png (27.83 KiB) Viewed 2366 times
Is it possible to manually change the sequence of these calculation surfaces before
reporting it to a document (like PDF).
Thank you in advance.
BR,
AntoonB
Re: Sequence selected calc. surfaces in Documentation report
Post by T.Magenheimer » Sun Nov 10, 2019 3:59 pm
Dear AntoonB,
Unfortunately, this is not possible. However, we have already added this item to our improvement list for one of the next evo versions.
