Water not giving correct effect with light fixtures
Archtube
Post by Archtube » Wed Jun 12, 2019 9:40 am
Hello!
I'm creating a landscape area which includes water. I have also used underwater luminaires, but for some reason the light is not showing through the water. I have checked all properties of the material for water and it seems fine. I can't find a way to fix it.
When i pan below the water I can see the source of light and I can also see the light distribution curve, but not the effect. Any ideas what could be the cause of this?
Thank you!
Re: Water not giving correct effect with light fixtures
Post by T.Magenheimer » Thu Jun 13, 2019 7:48 am
Dear Archtube,
Please read the following treads of our forum to hopefully answer your question:
http://dxboard.dialux.com/viewtopic.php ... ter#p91440
http://dxboard.dialux.com/viewtopic.php ... er#p102048
http://dxboard.dialux.com/viewtopic.php ... ter#p90446
Archtube
Post by Archtube » Thu Jun 13, 2019 11:34 am
Hi T.Magenheimer,
I have already read those threads and have taken all appropriate measures to tackle this issue. Despite the efforts, nothing has changed.
I have tried to create a water surface (0.001 mm) and put luminaires under it.
I have tried to create water as an extrusion volume
I have tried to use different luminaires.
Nothing has worked and it is the first time I have encountered this problem.
Just as a side note, I am working in outdoor and building planning (if that matters, but it shouldn't since I always work with outdoors and never had an issue like this)
I appreciate if you could help otherwise instead of suggesting other threads.
Thank you in advance
Archtube ltd
Post by T.Magenheimer » Tue Jul 02, 2019 12:36 pm
Dear Archtube,
Please have a look at the following video tutorial about how to construct pool lighting:
https://www.youtube.com/watch?v=W_oAfYi ... ex=23&t=0s
