Import DWG with 3D
giwi342
Import DWG with 3D
Post by giwi342 » Tue Feb 12, 2019 8:33 am
I've just started using DIALux and this looks great. Only wish I could change the colour of luminaire easier (e.g. with RGB sliders).
I have a DWG with drawing in 3D (building outside wall and a metal mesh in front of it). I am trying to install a luminaire between them to see how much light gets through and reflects back to the wall. Import DWG imports it as a plan and I think it does not recognise it as a 3D drawing. Also, I have tried adding material to the imported object, but it adds material to everything else except that.
Is it possible, or am I hoping for too much?
Thanks.
Re: Import DWG with 3D
Post by Csuleiman » Tue Feb 12, 2019 10:29 am
Dear giwi342,
In evo it is already possible to control the colour channels of the RGB luminaires individually (see screenshot below).
The DWG drawing serves in evo as a background plan, on the basis of which you must reconstruct the external and internal contours of a building.
You can assign each surface its own texture/material by holding down the SHIFT key while drag&drop onto the surface.
giwi342
Post by giwi342 » Wed Feb 13, 2019 11:08 am
It is quite hard to reconstruct something with a lot of small holes (e.g this Image).
As for RGB - hmm... guess the luminare file I got does not specify the lamps to be RGBW. Will keep trying.
Thank!
