Major TI calculation bug in evo 10.0
jkomar
Post by jkomar » Mon Oct 11, 2021 8:25 am
I'm using DIALux moslty for street lighting calculation. After the update to evo 10.0 i found that when there is an installation with 2 luminaires on the pole - the TI calculation goes wrong - the result drops to 0 or 1, which is not possible.
This bug makes the software for me almost useless in version 10.0.
sample of error TI calculation
2021-10-11 10_40_56-Clipboard.png (76.22 KiB) Viewed 925 times
The second issue is when the MF in external scene is changed after the calculation has been made - the program crashes.
This is a major bug, please help or fix.
BR,
JKomar
Best Regards,
Jarosław Komar
Re: Major TI calculation bug in evo 10.0
Post by Csuleiman » Tue Oct 12, 2021 9:36 am
Hello JKomar,
Unfortunately, we cannot reproduce the first problem with the TI value. Therefore, please provide us with the evo project file so that we could check the problem directly in evo 10.0. It would be of help if you could send us the link to this topic so that we could better assign this issue. Our email address is 'Support@dialux.com'.
The second problem is indeed a new bug in evo 10.0. Our developers will fix the bug in the next evo patch. Until then, we can only recommend that you adjust the maintenance factor in the uncalculated project, as the error only occurs in the calculated state.
jkomar
Post by jkomar » Wed Oct 13, 2021 6:32 am
I've sent 2 sample files and a ink to this topic.
Best Regards,
Jarosław Komar
Post by Csuleiman » Thu Oct 14, 2021 7:15 am
Hello JKomar,
We forwarded your project files to our developers for analysis. We will get back in touch with you as soon as we get a feedback from them.
Post by Csuleiman » Thu Oct 14, 2021 2:18 pm
Hello JKomar,
We have received feedback from our developer. Unfortunately, you have detected a new bug in the current evo 10.0 version. Our development team will fix this bug as soon as possible in the next evo patch.
Post by Csuleiman » Fri Oct 15, 2021 7:41 am
Hello JKomar,
Today we have released the evo 10.0 patch 1 version. We would like to recommend that you update to this version. In this patch, the bug has been fixed.
You can find the evo 10.0 patch 1 setup on our website or you can use the direct download link:
https://b2b.dial.de/index.php/s/fII5iKlIRzpgYCs
Users browsing this forum: jfykeaucq871 and 9 guests
