Dialux evo 10.0 contact information error
drapalakarol
Post by drapalakarol » Fri Oct 08, 2021 7:34 am
When trying to add a contact to a project I must enter all the contact information from scratch every time I want to use it.
Is this a bug or how do I save a contact so I can reuse it every time I create a new project?
Thanks,
Karol Drapala
Re: Dialux evo 10.0 contact information error
Post by Csuleiman » Fri Oct 08, 2021 8:34 am
Hello Karol Drapala,
Saving contacts should continue to work in evo 10.0. After entering data for a contact, it is automatically saved.
Once you have created several contacts, if you enter the first letter of a contact name, you will find a list with the history of all contacts entered so far and you can select a contact there - see screenshot below.
Does this work or is there a problem?
drapalakarol
Post by drapalakarol » Fri Oct 08, 2021 9:44 am
Hi thanks for your reply.
I have tried again and it is not saving for me.
I created a project with contact info and saved it (Image 1)
dialux screen.PNG (27.49 KiB) Viewed 546 times
When I open a new project no contact suggestions appear. (Image 2)
dial error.PNG (23.47 KiB) Viewed 546 times
Post by kvkozierowski » Mon Oct 11, 2021 4:57 am
Hi Karol,
The contacts are saved in the history when you change to another mode (e.g. "Constructrion" or "Light"). Unfortunately the contacts are not saved when you close evo or your project without changing to another mode. We will address this issue in one of the next evo versions.
