Erro
wesley
Erro
Post by wesley » Fri Sep 27, 2019 1:32 am
Every time I click Import Plant or error appears in the image.
what to do?
Error Message
Re: Erro
Post by Csuleiman » Fri Sep 27, 2019 7:41 am
Hello wesley,
Does the problem only occur when you want to select a specific plan or generally when you click the import tool? In case of a certain plan, please send us this file for further analysis.
wesley
Re: Erro
Post by wesley » Fri Sep 27, 2019 12:10 pm
Does the problem only occur when i want to click the import tool.
I can't even select the file. Because of the mistake before.
The link to this topic
https://dxboard.dialux.com/viewtopic.php?f=17&t=88378
Re: Erro
Post by Csuleiman » Mon Sep 30, 2019 6:10 am
Hello wesley,
We wonder if you could try the following suggestion to the solution: https://dxboard.dialux.com/viewtopic.php?f=29&t=83255
